Re: Farmall M. 1948
Posted by Janicholson on June 17, 2009 at 20:08:19 from (66.173.50.176):
In Reply to: Farmall M. 1948 posted by Bob Lanford on June 17, 2009 at 15:22:04:
Output of what? Belt pulley, PTO, are the only "outputs" The belt pulley drive comes off of the trans top with 6 bolts, then disassembles (you might need a press to get it apart and together.)
The PTO seal can be replaced Without taking it apart. Drive it so it points down hill (as steeply as you feel safe) so tranny lube stays inside. JimN
