Re: installing H 4 magneto on a TD-6 gas start diesel engine
Posted by teddy52food on June 18, 2009 at 05:55:57 from (209.237.111.169):
In Reply to: installing H 4 magneto on a TD-6 gas start diesel engine posted by ejensen on June 17, 2009 at 22:37:05:
Get it so it trips at TDC & it will run. If it backfires & don't run remove it & turn it 180 degrees or switch the wires across from each other. Does the impulse catch when you turn it CCW?
