Re: H- Starter will not Engage
Posted by Janicholson on June 19, 2009 at 07:00:17 from (66.173.50.33):
In Reply to: H- Starter will not Engage posted by ewalker on June 19, 2009 at 06:38:37:
Simple and correct answer.
The starter is jammed in the flywheel teeth. Loosen it at its mounting bolts and it will make a snapping sound when the teeth click out of the jam.
Been there with thousands of others. The tractor will now act normal in every way and start. To repair this a new clutch type starter drive will be needed (looks different, and is the solution, don't go for the same inertia drive in it now.
The discharge situation can be fixed easily by replacing the "one wire" alternator it has with a three wire system Delco 10SI series alternator. Cheap from an auto store, or wrecking yard.
To wire it up, use these diagrams. One of them is for the 10SI system. JimN
