Re: more 574 lube pump inf.
Posted by Bernard le mecano on June 21, 2009 at 07:36:39 from (75.158.246.207):
In Reply to: more 574 lube pump inf. posted by ohio dick on June 20, 2009 at 10:36:57:
Hi, the return flow from the PTO circuit, goes to the oil cooler, then to the lube circuit via the pipe over the transmission cover.You have full flow, if the PTO valve is in or out. Check for linkage bending,rust or dirt. May be the valve is not working ok. Does the PTO work normally? Bernard le mecano Quebec Canada
