Posted by Bob M on June 22, 2009 at 10:40:47 from (151.190.254.108):
In Reply to: M Stuck Valves posted by RickAshman on June 22, 2009 at 09:19:53:
Rick - First make sure it's not an ignition problem (fouled plugs, broken or swapped plug wires, etc).
If the spark is OK remove the rocker box and check valve action and valve lash on the affected cylinders.
You may find a momentarily sticking valve has caused a pushrod or two to become disengaged. It's not unusual for an M that's been sitting a while (it happens to one of mine the first start EVERY spring).
If a valve is stuck, try soaking it repeatedly with PB Blaster, ATF or your own favorite "snake oil" penetrant. GENTLY tapping/pushing down on the rocker above the valve stem between applications of penetrant will sometimes free up a lightly stuck valve.
However if the valve not work free you'll need to remove the head. And while the head's off check for bent pushrods on the affected cylinders.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
