Re: International A died and not starting
Posted by Jim Becker on June 30, 2009 at 16:07:43 from (173.57.160.166):
In Reply to: International A died and not starting posted by Larry Hardesty on June 29, 2009 at 20:30:18:
Is your magneto still functioning as a magneto or has it had an external coil hung on it? If it is still functioning as a magneto with the internal coil, that primary wire out of the coil has to be connected to the condenser or it will not produce any spark.
If it was converted with an external coil and uses battery power, then the internal coil should be disconnected and the ballast resistor comments are back in play.
If you clean the points with sandpaper, you might as well go ahead and replace them. If they weren't junk before, they will be after. Only use a point file on them.
