Jim, Thanks very much. Now it has an external coil and what looks like a condenser hung on the outside and connected to where the grounding switch cable connects on the outside of the magneto. I do not see a ballast resistor, unless the coil is the type that has one internally. I do not know the function of that condenser on the outside.
There is too much grease on the inside and probably some got on the points. The points are in sad shape, and I will replace them. That may be the problem right there. As you know, there is place to put a modest amount of light oil, but looks like someone got heavy on the grease. I will replace the points and set the gap and see what happens from there---unless you or someone else suggests something different.
Thanks. A big help, particularly on what to do regarding the primary wire. Yes, I will stay away from the sandpaper, and try not to get greasy hands on the points. These are times when I need smaller fingers. Almost could not get the screw loose to get the bottom part of the points out. I had visions of stripping the head of the screw. Who knows the last time the points were changed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
