A Question Of Ground....
Posted by Crazy Red Power in SE-WI on July 11, 2009 at 13:39:49 from (24.183.138.183):
On a 12v - ground system, is it ok to attach the ground cable to the frame using one of the starter mounting bolts? It's set up that way on my H & W6, but the H is 8v+ ground & the W is 12v+, both with a genny. Another thought popped up while thinking of the H. Should I have a resistor to the internal coil, seein's how I'm cheating with an 8v batt? I suppose, then, back to the attack on the 400! Thanks - Mike
