Re: A Question Of Ground....
Posted by old on July 11, 2009 at 13:55:04 from (4.245.4.35):
In Reply to: A Question Of Ground.... posted by Crazy Red Power in SE-WI on July 11, 2009 at 13:39:49:
Hooking your ground up to a starter bolt works real well and would you believe it does not matter if it is + or - ground. The starter will not care nor will the tractor
