Cause of intermittent knock in 45 M after it has run a while
Posted by Dick Binfield on August 19, 2009 at 19:19:44 from (207.91.20.182):
I have a 45 M which runs ok but knocks when it intermittently (misses) usually after it has run for a while. The oil pressure is very good but registers about 20 or so when it starts to knock. Oil level in the pan does not indicate it is low at any time. Any diagnostic hints on this problem or information as to where to start? I was told check the screen on the oil pump first and then bearings and then just as well do a overhaul.
