Re: Does this super AI sound right?
Posted by Roddy on September 06, 2009 at 18:37:27 from (70.74.68.230):
In Reply to: Re: Does this super AI sound right? posted by Roddy on September 06, 2009 at 18:25:24:
Spark is good on all cyl.
To check for a vacum leak I just spray WD40 around the intake manifold gasket and carb gasket right?
If the engine stumbles I have a leak?
