Re: Farmall 450 LP ?
Posted by John A. on September 11, 2009 at 12:11:31 from (76.1.122.170):
In Reply to: Re: Farmall 450 LP ? posted by Owen Aaland on September 11, 2009 at 05:34:59:
Owen, In theory you are correct. but not necesserly the case! It will be the valve that the entrance to it is at the highest point In the tank or any where above the liquid full line, that is the 80% full line. Look at your 450LP, both valves are at the same level on the tank, But the liquid valves draws off the bottom of the tank, and the vapor draws off the top. See what I mean? Hope this helps!
Later,
John A.
