Re: Farmall M burns POINTS!!!!
Posted by Bob M on September 16, 2009 at 09:14:21 from (151.190.254.108):
In Reply to: Farmall M burns POINTS!!!! posted by deerediesel on September 16, 2009 at 08:31:25:
Sounds like the wrong resistor is installed and is sending too much current to the points/coil.
With the ignition "on" and the engine STOPPED you should be see right around to 6 volts across the coil primary. Your reading of 11 - 12 volts is WAY too high.
Suggest installing a new ballast resistor. Get one for any 60's - 80's era Chrysler product - about $10).
Also suggest you spend a couple bucks extra and replace the condenser in the distributor. A failing condenser also shortens point life - though not to the extent you're seeing.
Or do as Hugh suggests and get a diesel(!)
