Re: F-20 With a BIG BLOCK FORD
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by john d on April 20, 2000 at 11:29:41 from (206.141.74.34):
In Reply to: F-20 With a BIG BLOCK FORD posted by Alan on April 20, 2000 at 10:06:57:
If the weight of the tractor is anywhere close to stock, the limiting factor as to what it can pull will be TRACTION. If this thing can't get any more traction than a stock F20, the drive train will probably live a long time. Start figuring out how to lock those tires into the dirt better, and the drive train suddenly becomes too weak. In short, if you keep it in 1st or 2nd gear, and don't weight it heavily, I don't think you'll hurt it much!
Post A Followup
: Re: Re: F-20 With a BIG BLOCK FORD
