Re: Rebuilt 340 that smokes, engine C135
Posted by Janicholson on September 25, 2009 at 07:07:48 from (199.17.6.222):
In Reply to: Re: Rebuilt 340 that smokes, engine C135 posted by jdbrad1 on September 25, 2009 at 06:37:00:
The problem is the oil rings.
The expander spacer is intended to be butted so that its ends meet together. The rails are then wound into the edges of that spacer. when installed, nothing is loose. In fact it is tough to move them in the ring groove with your fingers.
The rails should be installed such that their gap is 180 degrees opposite, and the but joint of the spacer is 90 degrees to those. Good Luck. JimN
