The sleeves, pistons and rings were part of the rebuild. I did an in frame rebuild with sleeves, pistons, rings, piston pins, pin bushings. Then I had the head rebuilt with new valves, valve guides, valve seats and springs. When I check the rings the oil ring expander spacer was not over lapped or connected it was in the groove loose with the two small rings top and bottom of it loose and moving free. As far as the cylinder walls they were new when I started and the tractor has less than 10 hours total on the rebuild. Could the temp be a problem with the parts not expanding the way they should?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
