Posted by Mike CA on September 27, 2009 at 20:40:33 from (99.28.152.102):
Between the belt pulley drive housing and the bearing cage there are shims for the belt pulley. In the parts guide it shows 3 shims, in succession, heavy, medium, and light. Tonight I pulled apart those shims to clean them and I found a total of SIX shims! 1-Heavy, 1-medium, 4-light (best I can determine).
Gordo told me I could pull a shim off if a particular spot was getting worn on the gear teeth. Well, I don't see any wear.
So, why were there 6 put on? Why do I need any shims? Should I put only the 3 on that the parts book shows, or should I put all 6 back on? I'm putting sealant between each shim to prevent it from leaking again. So maybe the sealant will make up for half the shims width?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
