Re: oil filter case retaining bolt Gasket
Posted by ScottyHOMEy on October 01, 2009 at 14:03:24 from (70.105.249.216):
In Reply to: Re: oil filter case retaining bolt Gasket posted by CGtractor on October 01, 2009 at 13:43:17:
I was going to suggest that it is just a soft copper washer, commonly referred to as a crush gasket.
Only misgiving I have is that when I went to look it up, the hollow retaining bolt on his tractor shows a couple of ears at the top that look like they might pass through a couple of notches that might be at the top of the bell. A copper gasket wouldn't go over those, so I'm wondering if his gasket might be made of something else, of a pliable material that might slip over those ears, that's maybe hardened up over the years the way the square o-rings at the bottom do.
If it weren't for that, I'd agree without hesitation, copper crush gasket.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
