Re: fuel leak on M
Posted by glennster on October 02, 2009 at 05:52:49 from (99.139.125.51):
In Reply to: Re: fuel leak on M posted by nydolphin on October 02, 2009 at 05:47:51:
you will prolly need to replace the sediment bowl assembly to get the fuel to shut off first. then tackle the carb. either there is a problem with the float hanging up, float level set too high, or possibly a hairline crack in the fuel bowl. with the fuel bowl off the carb, set it up on a table or something so it sits level, the fill the bowl with gas and see if it is leaking thru the casting or possibly the main load jet area. if not, look to the float, and needle and seat.
