TWheat: I assume your talking steering box, as the words bell housing are throwing me off a bit. My take on the word "bell housing" has always been "clutch housing".
I assume you are asking what holds the vertical shaft in place, within the gear box. I'm rusty on this, but as I remember a bolt or bolts hold the bearing up in place. I've forgotten how shaft is held in bearing, but it has to be a snap ring or cap screw above the bearing. It's close to 20 years since I had one apart, however something does hold shaft in bearing. I do remember the shaft and bearing come down together.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
