The oil in the bull gears (final drive) is separate from the oil in the rear frame unless someone has updated the housings to the later style. The change was to drill holes in the rear frame so that the oil could run between the rear frame and the axle housings. If it is updated the check/fill plug on the axle housing should have been cut off so that it can not be removed to indicate the change was made on that side. Some tractors out there have only one side done.
If you lost the steering and the tractor will not move out of the field you most likely have more problems than changing the oil is going to cure. What other symptoms do you have? Was there a change in noise? Do the rear hydraulics work? Does the PTO work?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
