Re: Model C Power Loss- Dies Under Load
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on April 23, 2000 at 10:59:20 from (12.75.196.224):
In Reply to: Model C Power Loss- Dies Under Load posted by Donald Bolt on April 23, 2000 at 10:48:08:
Donald are you seeing any white smoke discharging from the exhaust? Sounds like a head gasket problem from your description. I would guess that coolant is getting into one of the cylinders.
Post A Followup
: Re: Re: Model C Power Loss- Dies Under Load
