Posted by bc on December 14, 2009 at 13:14:12 from (65.66.85.240):
In Reply to: 706 Having a bad day posted by sdfarmall #2 on December 14, 2009 at 11:18:27:
Fuel issue. It will quit just like that and make you think its an electrical or a governor problem. After it sits and the carb fills with fuel, it will run again for a while. Probably have to use the choke to make it start and run. They will sometimes flow enough fuel to run around in low gear at high rpm even. But taking off in a higher gear requires an instantaneous burst of fuel and when the carb doesn't deliver, it quits which makes you think the gov is acting up or electrical. If you can run around for a long time in low, then it can't be electrical or the gear wouldn't make a difference.
Rust plugging the tank valve or sediment bowl. Could be at the screen at the carb. Maybe a little water in the system that has frozen. Get a empty tank and short hose, pull the plug from the bottom of the carb or the fuel line off the carb. It should run a steady stream for 5 minutes.
Post back with what you find. Then the fix can be ascertained. I fight it all the time and about due for another tank cleaning.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
