Posted by Gerry BN on December 20, 2009 at 12:00:14 from (86.134.193.197):
In Reply to: Re: Farmall BN Rims posted by ScottyHOMEy on December 19, 2009 at 14:23:09:
Scotty, my tyres are 9 00-24 11-24 measuring thr rims-if you view the section as a top hat, the centre is 4 1/2" with a 1 1/4" drop either side for the beading- i thought they were 8" but now wonder if 7" the lug overhangs by 1/2" (the 2 rivets are in the drop) and the inner face of the lug is 1 1/2" inside the flange drop (not central) My front is the wider lower single cast split rim. Regards Gerry
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
