Re: Super H won't start
Posted by Derrel on December 29, 2009 at 09:52:25 from (67.142.130.35):
In Reply to: Re: Super H won't start posted by El Toro on December 29, 2009 at 09:30:37:
I haven't check the manifold vacum yet, but that will be next soon as the battery gets recharged. I have double checked the spark wires and they are in the corect firing order. I have also checked the timming as you discribed execpt haven't taken the valve cover of to double check that both valves are closed (but they where when I put the engine back together). I am supecting it might be the manifold vacum as the gas only starts running out after I have cranked the engine over a few times. Assuming there isn't enough vacum what might cause that? I did put a rebuilt head on it and a new manifold with all bolts being tourge to specs.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
