international T340 crawler
Posted by tooltimejim on December 29, 2009 at 13:09:44 from (208.83.206.163):
Was thinking of buying a gas T 340 crawler, I think it's a 1959 or 60' with gas engine. I don't know enough about the international crawlers, and if parts are still available for repairs.The price is 2600.00 in running /working condition. thanks for any advice. Jim
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
