In working condition, that would be a good price. I owned a TD 340 for a while. Paid a good deal more, but the diesels are more and mine had a 6 way dozer blade on it. Parts that are common to the wheel tractors are available. The parts unique to the crawler are harder to come by. Engine and some drive train parts are same as the 340 wheel tractor. Some cautions. Make sure the steering brakes and clutches are working properly. If the brakes need work, it will be necessary to remove the tracks and then the final drives to get to them. This is a big job requiring heavy lifting equipment, etc. The brakes are disk brakes the same as the wheel 340 tractor. The way this thing steers is that you pull the lever on the side you want to turn. First it releases the clutch on that side and it will gradually turn. Pull back farther and it engages the brakes causing a hard turn. The one I had leaked oil out of the transmission seals onto the brake disks on one side. Brake on that side would not work and could not turn that direction very well. I discovered the drain holes in the brake chamber were plugged with mud. After cleaning those drains and a couple cans of brake cleaner squirted in there, got it to work sort of. Eventually sold it. Buyer fixed it up and is still using it some.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
