Re: Warming up the MCV on 706
Posted by Lee in Iowa on January 06, 2010 at 17:37:40 from (66.172.198.47):
In Reply to: Re: Warming up the MCV on 706 posted by pete 23 on January 06, 2010 at 10:11:41:
Running oil thru a hose will help on an open center tractor. It gets things working a lot quicker on my 856 and my neighbors 1066. You can have the tractor warmed up and working good and if you let it idle for a half hour below zero the oil will actually cool down unless you lock a lever and keep it pumping thru a hose.
