Posted by Erik Dekeyser on January 08, 2010 at 05:21:24 from (161.216.0.108):
In Reply to: 656 3pt lift problem posted by Steven Kautz on January 08, 2010 at 05:08:07:
There is a plug near the top lift arms or at least it looks like a plug but its a relieve valve or a bypas valve, anyway it unscrews very easy and you can replace it with a valve from a 886 or a 986 i think if i remember right the 656 is set at 1800 pounds or 2000. But the 886 is set for 2200 and the 986 is set for 2400. They are all the same looking plug and i changed mine to an 886 and it made the loader lift a lot more than it used to. You can check it out at your case IH dealer.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
