Re: farmall 300 dies when hot
Posted by d7fever on January 13, 2010 at 08:13:54 from (72.79.202.123):
In Reply to: farmall 300 dies when hot posted by cody jon on January 13, 2010 at 08:00:55:
Do you have a resistor inline for your coil? if not, it is your coil. Either put a 12 volt coil on or put in a ballast resistor. Or could be just a bad coil. If you are getting some backfire before it stops, it is probably your condenser.
Good luck
