Re: farmall h won't run
Posted by El Toro on February 06, 2010 at 13:21:21 from (64.12.116.73):
In Reply to: farmall h won't run posted by Glenn Stauffer on February 06, 2010 at 08:03:18:
I think you have some wires reversed. You should have a wire from your ignition switch to your distributor that feeds voltage to the distributor
when the ignition switch is in the on position.
Somehow you're feeding battery voltage to your starter and to the distributor. Before you changed this your starter would just crank the engine and you could not start the engine unless your ignition switch was in the on position. Is a solenoid used with this starter? Hal
