where are you located? i"m up near yorkville illinois. steering shaft can usually be sraightened too, worse case would be to cut a section of cold rolled bar stock and splice it in with a coupler or sleeve for the steering shaft. i"d also start soaking the motor now so it has plenty of time to loosen up. loosen the oil pan drain and see if theres water in there, if so drain it out. fill the cylinders with automatic trans fluid and pull the valve cover and dump some across the whole valve train and put the valve cover back on. you could also buy a gallon jug of pb blaster and fill with that too.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
