12v conversion wiring help!
Posted by binder300U on February 20, 2010 at 16:01:40 from (206.212.229.240):
I recently converted my 300u to a 12 volt system. It seems to be wired correctly, it starts, everything works, but to date i have fried two alternators! everything is fine for about 4 to 5 starts/runs- charging kicks in about 1500rpms. Then i start up the tractor, and suddenly it won't charge the battery(warning light stays on, no matter what the rpms).
electrical system components:
original 6v delco starter with new 12v solenoid
delco 4 pole ignition switch(came on the tractor when i got it) with poles for ACC, BAT, SOL, and IGN
delco 12v coil
delco 3 wire alternator
new repro IH ammeter
wiring:
(8ga)BAT post on alternator to (L) post on ammeter
(8ga)wire from B post on ammeter to large post on solenoid
(4ga)wire from same large post on solenoid to +battery terminal
(1ga) wire grom -battery terminal to body
(12ga)terminal 1 on alternator to ACC on ignition switch thru warning light- tho wires into and out of the warning light are 16ga
(12ga)terminal 2 on alternator to BAT on alternator
(14ga) SOL on ignition switch to small post on solenoid
(12ga) BAT on ignition switch to (L) post on ammeter
(12ga) IGN to + post on coil
(12ga)light switch to (L) post on ammeter
(12ga)cigar lighter to power out(always hot) on light switch
One thing i noticed when the alternator charges- the ammeter needle sits all the way at the top of the gauge at first, then drops down to about 2/3 up the gauge.
anyone have any insight into what the prob cold be? thanks alot.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
