Re: Not IH- Gehl 4640 Engine Issues
Posted by Wisconsin Cowman on February 28, 2010 at 20:19:50 from (108.1.54.252):
In Reply to: Not IH- Gehl 4640 Engine Issues posted by ihjeff on February 28, 2010 at 19:43:45:
You said that it runs for a minute and stops. After it stops when you turn the key to start it will it smoke? To me it sounds like you have a bad fuel pump. If you have like over a 1000hrs on it and it has never been changed I would try the fuel pump. They do go bad. Before all this happened did the skid loader feel like it was losing power? Will it start if you give it a shot of either after it quick’s. Nothing electronic controls the fuel on them.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
