Re: Starting Problem with a 300
Posted by Bill46 on March 29, 2010 at 10:53:25 from (192.88.212.44):
In Reply to: Starting Problem with a 300 posted by Siefring Red Farmer on March 28, 2010 at 16:41:02:
I would have to look at my manual....045 is way too much. Most IH systems back then were around .030 or so.
If you have a strong battery...check and insure the cables are good. Look for corrision under the outer coating near the terminal. If all that is good...sounds like a weak coil.
