756 German Diesel
Posted by Clynnt on April 01, 2010 at 18:16:22 from (67.237.43.101):
756 German Diesel .... With No Load - tractor seems to run fine up to 3/4 throttle ... but cuts out @ PTO rpms (2300) even if just sitting parked
When pulling disk .. RPMs drop when under a load ... I can give is more throttle … but only to the Ύ level as described above … anything past that .. the black smoke rolls & it cuts out …. Keep it down to Ύ rpms .. it’s fine until I lift the disk … then I’m back to the cutting out from too high rpms ..???
This is my first diesel tractor... I know the governor keeps RPMs up under a load on my Gasser ...??
I'm thinking fuel filter would be the first thing to check ... but though these symptoms … would probably be a give-a-way … to some experts …?
Any help will be appreciated
