Re: starting prcedure WD9
Posted by M in sask on April 04, 2010 at 17:51:41 from (69.168.161.83):
In Reply to: starting prcedure WD9 posted by M in Sask on April 04, 2010 at 13:07:51:
Thanks Jim for your reply I need a manual . but for now diesel fuel is coming out of what I think is the oil filler on pump ( spring loaded cap 3/4 ot so) when i drain oil out of pump I get fuel not oil .is the cock an inch or so from the bottom of the pump a oil level check? with right hand lever all the way up or in middle I can get it to fire on diesel but wont stay running. Thanks Merv
