Posted by Janicholson on April 25, 2010 at 11:05:35 from (199.17.6.222):
In Reply to: IHC UTILITY TRACTOR posted by lenray on April 25, 2010 at 10:57:06:
There are two ways to go. He can use additional valves on the right front of seat to ad more controls. 2way or one way operation are possible with IH valves by using a control switch on the valve. two valves can be stacked together on the front right. (should be a plate there to be reused on the outside of the final valve. Or He can put a separate pump running from the crank shaft out the front casting where the crank hole is located. This allows a higher capacity pump, and quicker loader operation. It will then need a reservoir and valves to attach to the loader. Recommended! Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
