Re: M vs Super M Block
Posted by Janicholson on April 27, 2010 at 17:40:20 from (64.61.211.116):
In Reply to: M vs Super M Block posted by Bouncer on April 27, 2010 at 17:33:26:
Yes and no. The engine is identical, the clutch and flywheel are smaller in the M and not compatible. Using the M's FW and a heavy duty clutch plate (maybe from HiCapacity company) will make it work. Jim
