new grease turning to oil?
Posted by FarmerDevin on May 03, 2010 at 09:53:56 from (75.107.64.56):
Has anyone had problems after regreasing front wheel bearings and having some grease turn to oil and run out the cap? I've had it happen before with NAPA's brand of grease in 4 lb tubs and now with Valvoline's extreme pressure, high temp, multi purpose red wheel bearing grease. I had been told not to use gasoline to clean hubs and bearings, that it would damage the new grease, but there have been many hubs that were caked full of abrasive grime. I was thrilled to find the latest set of hubs had been taken care of and didnt need any more than wiping out. So no gasoline in these, but the grease still drips oil. I expected Valvoline to be good quality grease. Any ideas?
