Re: Running Without Charging
Posted by IndianaRed on May 16, 2010 at 11:58:03 from (76.214.156.174):
In Reply to: Re: Running Without Charging posted by teddy52food on May 16, 2010 at 11:07:47:
Could it be the coil? Or condenser? Doesn't seem like the carb would just all of a sudden start sending too much fuel does it?
As I think through this, with my limited knowledge, I keep going to the coil, which I didn't check to see if it was hot. But if I leave it alone for awhile when I come back it's fine, like something cooled off that was causing it.
