Are you saying that you put your spacer under the sector gear. I have a very thin spacer or thrust washer there. That would make sense for the verticle travel. By placing the shim on the lower bolster I took out the play in it when I moved it back and forth horizonally. When I put the castle nut on the top the shim( made out of the old bushing that I took out)was drawn up into the the lower bolster really tight. Maybe the verticle play should be taken out by the spacer under the sector gear. If you would could you e-mail me a number in which I could talk with you personally. thanks for you comments on this.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
