Re: *Super -M- again*
Posted by old on July 05, 2010 at 12:13:27 from (4.245.4.120):
In Reply to: *Super -M- again* posted by gatorhide on July 05, 2010 at 11:28:03:
Either your push button start switch is bad or your battery is low and that can/will cause the switch to weld up and cause that. As for timing yes you can time it at least close to it. Pull the cap off but leave the rotor on. Turn the engine over till you have #1 at TDC and look where the rotor is. Where it points will be #1 and then hook up the wires as per the firing order and it should run. Now if you happen to get it at TDC but in the exhaust stroke then all you have to do is switch the wires out 180 and it then should run
