*Super -M- again*
Posted by gatorhide on July 05, 2010 at 11:28:03 from (24.155.13.131):
Well, the M still won't run.
I tried to start it and when I let off on the start button, it continued to turn over. I had to disconnect the + cable in order for it to stop turning over.
Is the new push start button malfunctioning ? Or is it the new on/off switch malfunctioning ? Or both ?
I took the distributor out and examined the stud bolt and the insulation on both inside and outside of distributor and did not detect anything there appearing wrong. I also made sure the points are set @ .020
When I tried starting the M again, it would backfire and this would be incorrect timing, but I couldn't get it to start so I couldn't set the timing.
I'd forgot to make a mark where the distributor was set at before removal.
Thanks again for your help! gatorhide
