Re: Farmall 560 gas - wont run under load
Posted by Matt 896 on July 18, 2010 at 03:35:47 from (64.222.186.170):
In Reply to: Re: Farmall 560 gas - wont run under load posted by The tractor vet on July 17, 2010 at 20:52:35:
I have not had much experience working on a 560 however I do know quite a bit about mechanical engine operation and theory and have never seen nor heard of an engine stalling from pre-ignition (unless it caused a failure of some sort)... Try not to over think the problem right out of the box. Start with the least intrusive diagnosis first and work you way up from there. I would have started off the same way you did with the tune up, plugs, wires, cap, rotor, coil, condenser. After that like the vet said look at you fuel flow. A quick check to see if it may be a fuel or air problem pull the choke out when the engine is in the process of stalling. If the RPM's come back up that's most likely where you problem lies. From there I would start looking at the carb, maybe a good carb kit, cleaning and adjustment. Check the govenor for proper operation and adjustment. After that I would look into the base engine, compression, valve springs, etc. Good luck! Matt
