Valve Lengths in a Super A
Posted by Sam Eubanks on July 19, 2010 at 06:57:37 from (148.168.127.10):
I ordered valves to replace the valves in a 1951 Super A. The valves I received are longer than the ones I have in the head by about an 8th of an inch. My question is, how much tolerance in valve length can the assembly allow? Am I safe to use the valves I received?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
