Re: Re: Re: Re: Re: Re: Re: Super M 6v to 12v conversion
Posted by Bob M - yer right Red... on June 06, 2000 at 11:24:44 from (192.232.120.194):
In Reply to: Re: Re: Re: Re: Re: Re: Super M 6v to 12v conversion posted by The Red. Question ltf on June 06, 2000 at 11:02:34:
Hey again Red - My diagram presumes you are reusing the existing (6 volt) coil. Only a single ballast resistor is required. Two resistors in series will reduce coil current too much and result in a weak (or no) spark, just as you suggest.
A 12 volt coil requires no resistor whatsoever (it's already inside the can...)
Point of information: There is no electrical difference between a ballast resistor and a 3 amp-rated "dropping resistor" - they're two names for the same thing.
Bob M
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Super M 6v to 12v conversion
