Re: Need help finding seals for Farmall H cross shafts
Posted by The Red on June 07, 2000 at 05:07:35 from (12.75.196.43):
In Reply to: Need help finding seals for Farmall H cross shafts posted by Harry on June 06, 2000 at 21:41:04:
Those are technically called bull cage seals. Call Ken Updike and make sure to order two per side. 608-455-2411.
The easiest way to get them out is to drill two large holes next to each other in the old seal about an inch deep. Then take a chisel to start prying it out, then use slip claw pliers. This will take you awhile for being the first time. Sometimes the guts of the seal will come out and you still have to chisel out the seal housing.
Post A Followup
: Re: Re: Need help finding seals for Farmall H cross shafts
