Re: Front bolster shaft removal
Posted by Dan G on July 25, 2010 at 20:44:53 from (184.8.138.128):
In Reply to: Front bolster shaft removal posted by Owen Aaland on July 25, 2010 at 17:26:41:
I may be able to get to it tomorrow. Is the sector gear the only thing holding up the whole shaft? That would surprise me that that gear would hold on that tightly.
Does the steering shaft wear out like the sector gear? does that need replacing too? I checked the free play before disassembly with the front wheels off the ground, and the play is between the sector gear and the worm. 1/4 steering wheel turn before effect. Don't care about that, but the front wheels wobbled on road gear something bad.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
