Bleeding 466 Lines
Posted by Bluebone on August 03, 2010 at 10:13:38 from (97.81.157.101):
I put a new set of injectors in the 466 in my 1640 Case IH combine. What is the most effective way to get the air out of the lines? It should only have air between the pump and the injector pump. Thanks in advance.
